M-Bus Meter will not communicate with the M-Bus X Driver
  • M-Bus Meter will not communicate with the M-Bus X Driver
‎2018-09-07 06:59 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:51 AM
A Controller with X Driver support has been loaded up with the M-Bus (or M Bus) X Driver and connected to a M-Bus to RS-232 converter (i.e. Westermo AD-01) but is not getting data from the M-Bus meter.
Note: This is M-Bus (Meter Bus) and not Modbus which is a different protocol
bCX1 and Netcontroller II 2nd Generation controllers with X Driver port enabled
MBus, M Bus, XDriver, X-Driver
Incorrect comm port settings for the M-Bus interface will stop correct communications to the M-Bus meters.
DefaultMode = Xdriver
Baud = Baud300
Parity = Even
Stopbits   = StopBit1
Datalength = Databits8
  1. Connect up and configure the system as detailed in the M-Bus manual as supplied (downloaded) with the M-Bus X Driver software.
  2. Unless specified otherwise in the manual for the specific 3rd party meter being used, set up the Comm port on the Controller with the above parameters:
  3. These settings should be entered and verified through the Command line, then printed back to verify they have been accepted.
  • 4749
