Loytec NIC_USB100 interface does not work with a new HP laptop
  • Loytec NIC_USB100 interface does not work with a new HP laptop
  • Chris_Asbury
    Chris_Asbury
  • sesa115370
    sesa115370
‎2018-09-06 10:33 AM
Some engineers are being issued with new HP Probook 6570b laptops, running Windows 7.  The Loytec NIC_USB100 network interface does not work with these machines, even when the latest Loytec drivers (version 4.1.4) are installed.
Lonworks
Windows 7
Plug'n'Play does not recognise the NIC_USB100 when it is plugged in and fails to install the drivers.
As a workaround, install a virtual machine running Windows XP on the HP Probook 6570b.  Install the Loytec software on the virtual machine.  The NIC_USB100 is then recognised and the drivers install correctly.
  • 12814
