Loytec L-VIS must be installed in an LNS Network, not a Vista Classic system.
  • Loytec L-VIS must be installed in an LNS Network, not a Vista Classic system.
  • Sacco
    Sacco
‎2018-09-06 01:43 PM
Can the Loytec L-VIS be used in a Vista Classic scenario?
Loytec L-VIS
The need to have a touch screen interface to a Vista Classic network.
The L-VIS cannot be used in a Vista Classic system because it uses SNVTs to interface the Lon. LNS must be used.
A solution to a Vista Classic scenario would be to touch screen PC or tablet to interface the graphics in an Xenta Webserver (5xx,7xx).
  • 5364
