Creating and Using Lookup Tables for Resistive AI Devices in Sigma Controllers
  • Creating and Using Lookup Tables for Resistive AI Devices in Sigma Controllers
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
‎2018-09-06 01:37 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-04 11:01 PM
Sigma controllers require accurate interpretation of resistive analogue input (AI) signals. When using non-standard sensors such as 10k Type 2 or Type 3 thermistors, incorrect resistance values can trigger hardware alarms or result in inaccurate readings. A custom lookup table must be created to ensure proper operation.
Satchwell BAS & Sigma
Satchwell BAS & Sigma UNC controllers
Sigma controllers interpret resistance values as a percentage of a 2V signal at the A/D converter. The default lookup tables are designed for specific sensor types (e.g., D?T range). When integrating other resistive sensors like 10k Type 2 or Type 3 thermistors, the controller may not recognize the input correctly, leading to hardware alarms or misread values. A custom lookup table is required to translate resistance values into valid input percentages.
Step-by-Step Process to Create a Lookup Table
  1. Gather Sensor Data
    Obtain resistance values at various temperatures from the sensor’s datasheet
  2. Use the Sigma Calculation Formula
    R1*250 / R1+14700
    Where:
    • R₁ = Sensor resistance
    • 14700 = Resistor value on the AI card
    The circuit shown below is a typical example of an AI channel for a resistance input.
    To ensure the circuit resistance does not exceed 10kΩ, it is recommended to place a 10kΩ shunt resistor in parallel with the sensor.
  3. Create the Lookup Table Object
    • Enter the calculated input values into a new lookup table object in Sigma.
    • Ensure the table covers the full operating temperature range of the sensor.
  4. Assign the Table to the AI Object
    • Link the custom lookup table to the relevant analogue input object in Sigma.
  5. Download and Apply
    • Use Sigma System Setup and Diagnostics to build and download the new lookup table to the controller.
  6. Verify Operation
    • Check that the AI object displays correct temperature values.
    • Use programmable objects if additional formatting or scaling is needed.
Examples
  • Type 2 Resistances.pdf
  • Type 3 Resistances.pdf
  • Lookup Table Details
    • Column C: Raw sensor resistance
    • Column D: Controller input resistance with 10kΩ shunt resistor
    • Columns E & F: Example lookup table values (percentage of 2V signal)
  • Satchwell BAS & Sigma
Tags (3)
  • 5550
  • CraigEllis25
  • DavidChild19
