LonWorks on an AS and replacing the template without deleting devices
  • LonWorks on an AS and replacing the template without deleting devices
  • sesa139513
    sesa139513
‎2018-09-06 11:04 AM
StruxureWare Building Operation site with LonWorks interface
Site would like to replace the XIF template without deleting devices
Unfortunately there is no way to replace the template without removing all devices. Even if the site is fully commissioned and devices are installed, the site must be re-commission and bind everything again. The template cannot be replaced without deleting the devices installed.
  • 11253
