Logged out from Webstation when opening TGML Graphics
  • Logged out from Webstation when opening TGML Graphics
  • sesa150555
    sesa150555
‎2018-09-07 06:43 AM
  • When navigating in TGML pictures, some are opened, a few then the picture "hangs" and I get thrown out from Webstation and have to log in again.
  • Get logged out form webstation after opening a couple of TGML graphics
TAC Vista 5.1.x
TAC Webapps 5.1.x (Webstation)
Windows 2003 Server
If the site admin has set the  properties on the application pools to restrict the memory a process can use this restriction will be applied to the SE.ASP.NET v4.0 Classic application Pool that webapps are using.
These restriction have to be taken or set to a higher value.
  1. Open IIS Manager
  2. Expand Application Pools and right click on SE.ASP.NET v4.0 Classic
  3. Select properties
  4. Uncheck Maximum virtual memory and maximum used memory (or type in higher values)
  5. Click ok and restart the website.
  • 4702
