Links Reported as Mis-match After Downloading Configuration to Unifact Controller
  • Links Reported as Mis-match After Downloading Configuration to Unifact Controller
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • Gary
    Gary
‎2018-09-11 03:48 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-23 07:24 PM
When downloading a configuration to a Unifact controller using VisiSat 2.1, the first byte of the download is incorrectly set to 0, resulting in a node link mismatch.
Satchwell MicroNet
VisiSat 2.1
The initial byte of the configuration download is incorrectly set to 0, which disrupts the node link table within the controller. This leads to a mismatch between the configuration in VisiSat and the controller.
Incorrect entry for Pair 0Incorrect entry for Pair 0   Correct entry for Pair 0Correct entry for Pair 0
  1. Download the Required Scheme
    • Whether it's a new scheme or the same one already present, re-download it to the Unifact controller.
  2. Enter Bubbleland
    • A "links mis-match" message will appear.
    • Select "Fix Later" to proceed.
  3. Repair the Links
    • Focus on any object link.
    • Break the link.
    • Then re-make the link.
  4. Verify Configuration
    • This action rewrites the node link tables in the controller.
    • Re-enter Bubbleland to confirm that the configuration now matches the one in VisiSat.
Important Notes:
  • This procedure must be repeated each time the controller configuration is downloaded.
  • Satchwell MicroNet
Tags (3)
  • 13102
  • CraigEllis25
  • mismatch
