Linkage kits to be used with Satchwell ALE (s) , ALi, ALX (s), ALM (s) on Schneider Electric Venta V and VG Valve bodies
  • Linkage kits to be used with Satchwell ALE (s) , ALi, ALX (s), ALM (s) on Schneider Electric Venta V and VG Valve bodies
  • DavidChild
    DavidChild
‎2018-09-06 10:23 AM
Linkage Kits
Linkage kits to be used with Satchwell ALE (s) , ALi, ALX (s), ALM (s) on Schneider Electric Venta V and VG Valve bodies.
Use the L8TV linkage kit part no. 914-1080-000 on V type valve bodies e.g. V211, V211T, V311, V311T, V231, V241, V212, V222, V232, V292, V341
Use the L9TVG linkage kit part no. 914-108-000 on VG type valve bodies e.g. VGS211F, VG221F, VG311F
  • Field Devices
  • 13303
