Limitation on Echelon PCLTA & NIC709-USB for one single PC
  • Limitation on Echelon PCLTA & NIC709-USB for one single PC
  • Sampath_Konda
    Sampath_Konda
‎2018-09-06 01:02 PM
How many Echelon PCLTA & NIC709-USB's can use for one single PC
TAC Vista 5.x.x
Echelon PCLTA
NIC709-USB
Requirement to know, If we can run more than one PCLTA & NIC709-USB's on a single PC.
There is no limitation on Echelon PCLTA & NIC709-USB's to use in single PC. As long as the PC has a slot for LTA & USB to insert then can be used.
  • 6667
