Limit of Function block under a Local node
  • Limit of Function block under a Local node
  • sesa150561
    sesa150561
‎2018-09-06 09:11 AM
  • How many Function block can i add under a Local node
  • Struxureware Server (1.6)
Struxureware was built around that 50 function block should be supported under a local node
Struxureware was built around that 50 function block should be supported under a local node however we never added a limit so you can add more, this is however not supported.
  • 17382
