License activation stops at 80% or License Administrator crash
  • License activation stops at 80% or License Administrator crash
‎2018-09-06 07:54 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:12 AM
Two related issues are covered in this article
  1. While attempting to activate a customer or demo license, the activation process stops at around 80%.
  2. When clicking the "Diagnostics" tab in the License Administrator it crashes with a "System.DllNotFoundException" error.
System.DllNotFoundException: Unable to load DLL (Tac.Nsp.Archive.Licensing.Client.dll)
  • First detected in Windows 10
  • First detected with Microsoft Visual C++ Redistributable 2012 (VC++ 2012)
  • License Administrator
There can be two reasons why this happens
  1. If the activation process stops at around 80%, but the License Administrator does not crash when the "Diagnostics" tab is selected, the license system needs to be completely reset.
  2. If the activation process stops at around 80%, and the License Administrator crashes when the "Diagnostics" tab is selected, Microsoft Visual C++ components need to be repaired.
Refer to solutions below depending on the issue detected.
Solution 1: Resetting the license system
The process to reset the license server system is covered in Resetting the License Server. In some cases, a deeper reset can be required. For that, a tool called "SBO License Server Reset" can be downloaded from the Community.
Solution 2: Repairing Microsoft Visual C++ components
Method 1
  1. In Control Panel, click Uninstall a program in the Programs group.
  2. In the programs list, locate Microsoft Visual C++ 2012 Redistributable (X64) - 11.0.61030 or Microsoft Visual C++ 2012 Redistributable (X86) - 11.0.61030, depending on your system architecture.
  3. Right-click the entry name, and then click Change.
  4. In the Modify Setup dialog box, click Repair.
  5. After the repair process is completed, restart the computer if you are prompted to do this.
Method 2
  1. Run the Modify Setup repair functionality for Microsoft Visual C++ Redistributable by starting the installer. VC++ installers
  2. In the Modify Setup dialog box, click Repair.
  3. After the repair process is completed, restart the computer if you are prompted to do this.
Tags (5)
  • 19249
  • 75%
  • qc28069
  • qc32677
  • StephenYang25
100% helpful (1/1)
