Large data base log file causes Continuum to run very slow and/or crash.
  • Large data base log file causes Continuum to run very slow and/or crash.
‎2018-09-10 10:04 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:37 AM
SU CyberStation
MS SQL Express
Warning
When Continuum starts and attempts to connect to the DB it takes too long due to the size of the log file (14GB in the case covered by this article)
Shrink the database.
Go to http://technet.microsoft.com/en-us/library/ms190757.aspx for steps from Microsoft to shrink the database files.
Tags (4)
  • 8195
  • continuumlog
  • continuumlog.ldf
  • ldf
