Language Pack for each release of SmartStruxure
  • Language Pack for each release of SmartStruxure
‎2018-09-11 04:27 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:50 AM
Language Packs are required for each new release of SmartStruxure
On each Change of revision, Maintenance, Service Pack, Hotfix or New Release requires the need for new Language Package
The Language Pack is built for each specific version of Building Operation. There must be a language pack specifically built for each build, i.e., for 1.5.0.3003 you need a language pack built for that specific hotfix 1.5.0.3003 version.
Example: One language pack is needed for Building Operation 1.5 and another language pack is required for Building Operation 1.5.1.
Language Packs are available on the Exchange Extranet
For further information on Language Packages and how to install then refer to the Online Help Topic; Language Packages
For more information on creating specific Language packages, please contact your corresponding regional category manager via the following email addresses:
  • Americas: Americas.EcoStruxureBuilding@schneider-electric.com
  • EMEA: EMEA.EcoStruxureBuilding@schneider-electric.com
  • Asia Pacific: AsiaPac.EcoStruxureBuilding@schneider-electric.com
  • 12995
