LMTools crashes during diagnostics tests
  • LMTools crashes during diagnostics tests
  • SESA150559
    SESA150559
‎2018-09-06 12:46 PM
In older versions of Vista (<5.1.5), LMTools version 11.4 is used, and seems to crash sometimes when using the diagnostics functions.
Vista 5.1.4 and older
Unstable software
Upgrade LMGRD.exe and LMTools.exe by replacing them with files of version 11.6 that can be found in TAC Vista versions 5.1.5 and later.
  • 7170
