Keep others from using local TAC Vista IV licenses
  • Keep others from using local TAC Vista IV licenses
‎2018-09-06 03:24 PM
How do you keep others from using my TAC Vista IV licenses?
Vista IV Licensing
Networked PCs will look for licenses outside of their local drives. On a shared engineering drive, this can cause problems.
In order to have your PC set up so that it does not share its license over a network:
  1. Go to Start > Run > Type in regedit
  2. Click OK
  3. Go to HKEY_LOCAL_MACHINE > SOFTWARE > Aladdin Knowledge Systems > Privilege Licenser > Applications
  4. Click on PLServe
  5. Double click on Network
  6. Change the 1 to a 0
  • 1198
