Kamstrup energy/heat/flow/cool meters pressure class
  • Kamstrup energy/heat/flow/cool meters pressure class
  • sesa119747
    sesa119747
  • SESA150559
    SESA150559
‎2018-09-11 04:00 AM
What is the maximum system pressure for the meters?
Kamstrup
Heat meter
cool meter
flow meter
It is important to make sure that the system pressure does not exceed the maximum pressure specified for the components included.
Depending on which meter is chosen, it is either 16 Bar (PN16) or 25 Bar (PN25). This is defined in the charts that are available here:
Heat/Flow Meter
  • Field Devices
  • 13490
