JavaScript function to determine if a TGML graphic is being run in Workstation or Webstation
  • JavaScript function to determine if a TGML graphic is being run in Workstation or Webstation
  • sesa177673
    sesa177673
‎2018-09-06 01:27 PM
Is it possible to determine if a TGML graphic is being run in Workstation or Webstation?
TGML Graphics Editor 1.1.X
Vista 5.1.X Workstation
TacWebApps 5.1.X (Webstation)
There are differences in the rendering of graphics between Workstation and Webstation. Sometimes this leads to the necessity of creating two sets of components depending on where the graphics will be presented. By being able to programmatically determine the environment, one set of components can be used regardless of the presentation, reducing engineering time.
The results of the JavaScript function Packages.java.lang.System.getProperty can determine whether the viewer is currently in Vista Workstation or not.
Note: This is not a supported function in TGML. Because it is unsupported, it is subject to change without notification, and should be used accordingly at your own risk.
  1. Create a document-level script tag that runs OnDocumentLoad.
  2. Determine the current Vista version (and keep potential future upgrades in mind as well). The implementation of the property changed in an upgrade from Vista 5.1.4 to Vista 5.1.5.
    • If the system is Vista version 5.1.4 and prior, use the following function:
      if (Packages.java.lang.System.getProperty("browser") == "ActiveX Scripting Host")
      If the statement is true, then the graphic is being run in Workstation.
    • If the system is Vista version 5.1.5 and later, use the following function
      if (Packages.java.lang.System.getProperty("java.runtime.name") == "IKVM.NET")
    • The following script can be run for any version of Vista 5.
        returns what browser Tgml is viewed in (Workstation==false,Webstation/Webserver==true)
      var getBrowserType = function() {
       var browser = false; // initiates browser indication variable as Webstation/Webserver
       if (Packages.java.lang.System.getProperty("browser") != null) { // checks Vista version
        // evaluated for Vista is 5.1.4 or earlier
        if (Packages.java.lang.System.getProperty("browser") == "ActiveX Scripting Host") {
            browser = false;   // indicates variable as Workstation
        } else {
           browser = true;    // indicates variable as Webstation/Webserver
       } else {
        // evaluated for Vista 5.1.5 or later
        if (Packages.java.lang.System.getProperty("java.runtime.name") == "IKVM.NET") {
        } else {
        return browser;     // returns browser indication
  • 5865
