JACE-645-R2 will not learn BACnet devices on its MSTP trunk and is spewing out the following message in the Application Director. devctl rx frame failed: No error java.lang.Runtime...
  • JACE-645-R2 will not learn BACnet devices on its MSTP trunk and is spewing out the following message in the Application Direc...
  • Kim_Baze
    Kim_Baze
  • WaynePeters
    WaynePeters
‎2018-09-06 09:28 AM
java.lang.RuntimeException: mstp rcv failed
at tridium.nre.qnx.mstp.QnxMstpDriver.rcvFrameJNI(Native Method)
at tridium.nre.qnx.mstp.QnxMstpDriver.access$0(QnxMstpDriver.java)
at tridium.nre.qnx.mstp.QnxMstpDriver$MstpTrunkListener.run(QnxMstpDriver.java:287)
at java.lang.Thread.run(Unknown Source)
G3 version 3.8.37
Issue with the platform drivers in G3 (3.8.37) that interface with R2.
Install a clean distribution using 3.6.47 and commission with 3.6.406.
  • TAC IA Series
  • 16618
