It is possible to make connections to the output side of a DO or AO in Menta
  • It is possible to make connections to the output side of a DO or AO in Menta
‎2018-09-07 01:00 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-23 06:32 AM
TAC Vista
Menta
Connecting to the back end of an AO or DO ensures that the value being used by the Menta application is always in sync with the value in the Vista Workstation/OP. Any AO or DO could be put in forced-by-operator mode, and if the Menta application does not use this down the line, the desired results may not occur.
You can click on the right side of the output block and connect it to other blocks.
  • 2057
