It is not possible to edit a database offline using the MNet-CI that is installed as a part of PSI 4.1.
  • It is not possible to edit a database offline using the MNet-CI that is installed as a part of PSI 4.1.
‎2018-09-07 03:47 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:50 AM
It is possible to edit a database offline using the MNet-CI that is installed as a part of PSI 4.1?
  • PSI 4.1
  • MNet-CI
The templates and default database files are not installed by the PSI 4.1 installer.
The templates and default database files, PSIv4.10_MN-CI_Templates.zip can be downloaded from Extranet.
Install the templates in the "mnetci" folder and the database folder in the PSI parent folder.
  • TAC IA Series
  • 3911
