Issue importing CSV file, no error seen but import fails
  • Issue importing CSV file, no error seen but import fails
  • Dave_Shore
    Dave_Shore
  • AbeMeran
    AbeMeran
‎2018-09-06 12:36 PM
Last Updated: Dave_Shore Schneider Alumni (Retired) ‎2022-12-14 07:20 AM
CSV file that has been edited with Excel does not import.
There is no error given but the import has no effect.
Andover Continuum
CyberStation
This problem can occur if the application used to edit the CSV file adds hidden characters.
Make sure the file contains ONLY plain text.
Use a simple text editor such as Notepad to avoid this issue
Tags (2)
  • 7441
  • DavidShore22
