Is there any way to segregate the IP level BACnet devices under the 'BACnet Devices' folder in CyberStation?
  • Is there any way to segregate the IP level BACnet devices under the 'BACnet Devices' folder in CyberStation?
  • AbeMeran
    AbeMeran
‎2018-09-06 10:48 AM
Site has many IP level BACnet devices from different vendors and want to separate them into different folders.
CyberStation
Documentation
Unfortunately there is no way to segregate the IP level BACnet devices in CyberStation.
The 'BACnet Devices' container is managed by the system and the user is not allowed to create or move  folders under it.
  • 12066
