Is there a way to populate an array in the declaration line as in other programming languages?
  • Is there a way to populate an array in the declaration line as in other programming languages?
  • sesa177673
    sesa177673
‎2018-09-11 06:59 AM
Is there a way to populate an array in the declaration line as in other programming languages i.e. Numeric numbers[4] = {1, 2, 4, 8}?
StruxureWare for Building Operation Script Editor
When defining an array in Script Editor the user may wish to populate the array with initial values.
The way to populate an array in Script Editor is to initialise each element individually.
  • 15717
