Is there a way to display only points currently in alarm in the Alarm Console?
  • Is there a way to display only points currently in alarm in the Alarm Console?
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:33 PM
G3, Workbench (all versions)
Only want to display points currently in alarm in the Alarm Console?
Yes, the Alarm Console’s filter is used to control what alarms are displayed in the Alarm Console window.
  1. Double-click on the ConsoleRecipient object
  2. Click on Filter at bottom of window
  3. Check the Source State box.
  4. Click on the Source State chevron to show filter options
  5. Select the alarms states, Offnormal and Fault. Only alarms currently in the Offnormal and Fault states will be displayed in the alarm console window.  (Items not checked will not be displayed.)
  6. Click OK and OK to save.
  7. Click File from the menu and Refresh to update change.
Only alarms that are currently in a Fault or a Offnormal state will be displayed in the Alarm Console window.
  • TAC IA Series
  • 5688
