Is there a way to change the date and time on a Niagara R2 UNC via a web browser?
  • Is there a way to change the date and time on a Niagara R2 UNC via a web browser?
‎2018-09-10 05:25 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:50 AM
Is there a way to change the date and time on a Niagara R2 UNC via a web browser? Typically this may be required where a standalone UNC with WEB-UI has been installed and the end user has no access to Workplace Pro since no Enterprise Server is used in this configuration.
Niagara (versions 428 or later), UNC-410, UNC-510, UNC-520
Standalone UNC
The webtime.jar file and webtime.html file were produced to provide the functionality to change the date and time, via a browser, for an UNC running I/A Series release R2.301.428 and later.
The webtime.zip, which contains both the webtime.jar file and webtime.html file along with the AT05-03 Technical Service Bulletin, can be downloaded from the Exchange Download Center.  Click on the webtime.zip link to download the needed files.  The webtime.zip file can also be located by entering “webtime” in the search window of the Exchange Download Center.
Follow the instructions listed in document AT05-03 on how to install and use the webtime applet.
  • TAC IA Series
  • 6703
