Is there a conduit box accessory for the I/A Series VAV controllers?
  • Is there a conduit box accessory for the I/A Series VAV controllers?
‎2018-09-06 02:03 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:03 AM
Some jobsites require the use of conduit for all wiring between controllers. Is there a specific enclosure made for this purpose?  A general purpose enclosure such as the ENCL-100 can be used but must be punched or drilled to fit the damper shaft.
TAC IA Series
MN-FLO / MN-FLO3T
MNL-V1RVx / MNL-V2RVx
MNB-Vx
Installation manual with reference to part number was misplaced.
MNA-FLO-1
This enclosure is listed as an optional item in the installation manuals for all VAV controllers listed above.
Click here to see F-26282-5, Installation Instructions for the MNL-V1RVx and MNL-V2RVx.
Click here to see F-27346-4, Installation Instructions for the MNB-V1 and MNB-V2
Click here to see F-25718-6, Installation Instructions for the MN-FLO and MN-FLO3T
  • TAC IA Series
  • 5014
