Is the new PSI / XPSI rev 4.1 compatible with Windows XP and Vista?
  • Is the new PSI / XPSI rev 4.1 compatible with Windows XP and Vista?
‎2018-09-07 04:26 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:49 AM
  • PSI / XPSI rev 4.1
  • Windows XP and Vista
Install PSI / XPSI rev 4.1 in a Windows XP or Vista Operating System (OS)
The new PSI / XPSI rev 4.1 is compatible with Windows XP and Vista. Download PSI rev 4.1 from The Exchange. The zip file includes an installer and a READ.ME file that includes Release Notes and Installation Instructions.
Note that the Patton Electronics RS-232 / RS-485 converter that has been widely used with the earlier versions of PSI (3.13) will not work with the new PSI / XPSI rev 4.1.  The B&B Electronics model USOPTL4 USB converter has been successfully tested with PSI / XPSI rev 4.1. Other recommended converters are listed in the Release Notes.
  • TAC IA Series
  • 3232
100% helpful (3/3)
