Is part number 40-1758, end of line resistor, still available for purchase through Schneider Electric?
  • Is part number 40-1758, end of line resistor, still available for purchase through Schneider Electric?
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:32 PM
Network 8000, IA Series BACnet Controller
Part is no longer available for purchase through Schneider Electric
Part number (40-1758) specified for the 120 ohm EOL (end-of-line) termination resistor is no longer available for purchase through Schneider Electric.  The resistor is utilized for RS-485 communications trunks (e.g. Network 8000, BACnet, etc.).  This resistor is a common part and is readily available for purchase through electronic stores or catalogs.
The specification for the resistor is as follows:
Nominal value: 120 ohm
Tolerance: +/- 5% or better
Power rating: 1/4watt metal film
Temperature coefficient: +/- 200 PPM or better
Maximum voltage: 250 volts
  • TAC IA Series
  • 5692
