Is it possible to upgrade the memory in an older ENC-520-2 from 128mb to 256mb?
  • Is it possible to upgrade the memory in an older ENC-520-2 from 128mb to 256mb?
  • sesa116868
    sesa116868
‎2018-09-06 12:36 PM
Customer has an older ENC-520-2 and has run out of memory for his station programming.  His ENC has only 128mb of memory, not the 256mb of memory in the current ENC-520-2 controllers.
ENC-520-2 or ENC-520-2-N manufactured in Rockford (SN xxxxxB) prior to BootFlash upgrade.
Manufacturing change.
The base memory (128mb) version of the ENC-520-2 cannot be field upgraded to extended memory (256mb) due to other component changes on the controller circuit board.
  • TAC IA Series
  • 7450
