Is it possible to upgrade Vista's log database directly from SQL 2000 to SQL 2008?
  • Is it possible to upgrade Vista's log database directly from SQL 2000 to SQL 2008?
  • sesa177673
    sesa177673
‎2018-09-10 11:16 PM
Is it possible to upgrade Vista's log database directly from SQL 2000 to SQL 2008? Version 5.1.7 no longer supports SQL MSDE or SQL server 2000.
Upgrade to Vista 5.1.7 from a vista version running with SQL 2000.
Upgrading older Vista sites to run with Vista 5.1.7 (or future versions).
The simple answer is yes, it is possible to upgrade from SQL server 2000 but SQL server 2000 SP4 needs to be installed first. Follow the link below to go to Microsoft's download site:
SQL 2000 SP4
There are a number of considerations which are explained in the attached White Paper from Microsoft.
  • 8034
