Is it possible to see a list of all the signals in the vista system that are overridden manually?
  • Is it possible to see a list of all the signals in the vista system that are overridden manually?
  • sesa177673
    sesa177673
‎2018-09-06 03:00 PM
Vista 5.1.X
It is important for the customer to know which signals are manually overridden to be able to make appropriate decisions about a plants' status.
There are 2 main options available:
1. Use Vista's search tool -the screen shot below shows which criteria to use. You can of course include other points in the filter.
2. Create a report and link to the signal's 'manual control' property. This option would have the advantage of being able to trigger the report via a button in TGML and that the layout can be configured according to the customer's specifications. However, it will take a bit longer to configure the report initially.
-Open the report and via the Vista reports addin configure a vista link to a value as shown below.
  • 11400
