Is it possible to remove the folder tree and alarm pane from webstation?
  • Is it possible to remove the folder tree and alarm pane from webstation?
  • sesa177673
    sesa177673
‎2018-09-10 04:51 AM
Vista webstation 5.1.X
Certain users have access to graphics and nothing else. It would therefore be better to be able to maximize the graphic resolution and not see the other panes.
The folder View and Alarm View can be removed by editing the DefaultPage.aspx file. The DefaultPage.aspx file can be found in the folder C:\Inetpub\wwwroot\TACVistaWeb51X.
  • 6635
