Is it possible to dump objects to text from a PE program?
  • Is it possible to dump objects to text from a PE program?
  • AbeMeran
    AbeMeran
‎2018-09-06 11:08 AM
How to dump object from a PE program
CyberStation
Documentation
Use the DUMP keyword to dump objects from a PE program running in CyberStation.
Example:
Dump MyNetwork\MyController\MyObject to "C:\Temp\MyObject.txt"
The object will be exported in DUMP format, there is no way to do the same in CSV format.
  • 11097
