Is it necessary to commission an MNB series controller if it is being used in a standalone application?
  • Is it necessary to commission an MNB series controller if it is being used in a standalone application?
  • sesa116868
    sesa116868
‎2018-09-06 12:38 PM
Single standalone MNB series controller
Using an MNB-300 controller to control a small RTU via an attached MN-sx sensor during construction.
No.
Commissioning is needed only when the device is being configured to communicate via its BACnet interface.
  • TAC IA Series
  • 7372
