Is an existing IMI video frame grabber supported by Datacard?
  • Is an existing IMI video frame grabber supported by Datacard?
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 03:30 PM
Video Badging conversion from IMI to Datacard
IMI and Datacard are two different platforms with a defined upgrade path between them.
The Flashpoint and Flashpoint lite, as most of the TWAIN devices are supported by the Datacard system. However, if the grabber card you have is not supported, a new card can be purchased from Datacard.
  • TAC INET
Tags (3)
  • 923
  • Datacard
  • ID Works
