Is Windows 7 Enterprise Supported in Continuum versions 1.93, 1.94, 1.94SP1 and 2.0x
  • Is Windows 7 Enterprise Supported in Continuum versions 1.93, 1.94, 1.94SP1 and 2.0x
  • sesa116827
    sesa116827
  • Sampath_Konda
    Sampath_Konda
‎2018-09-06 01:31 PM
 Windows 7 Enterprise is not listed in the compatibility matrix for Continuum versions 1.93, 1.94, 1.94SP1 and 2.0x
 Windows 7 Enterprise is not listed in the compatibility matrix as a supported OS for Continuum versions 1.93, 1.94, 1.94SP1 and 2.0x
 All versions of Windows 7 require product activation.
 Windows 7 Enterprise can only be activated with a Volume License MAK or KMS
 Key if it is not activated against a local KMS server. Enterprise requires a
 VL KMS/MAK out of the box or activation against a local KMS server. It can
 be rearmed up to 3 times.
 Windows 7 Ultimate edition activates conventionally via the internet to
 Microsoft activation servers.
 Unless you are in a business enterprise environment, then Windows 7
 Ultimate should be your choice.
The Windows 7 Enterprise features and code are the same as Windows 7 Ultimate. Windows 7 Enterprise is supported.
 Code is the same as Windows 7 Ultimate.
  • 5747
