Is TAC Vista webstation 5.1.X supported on Windows 7?
  • Is TAC Vista webstation 5.1.X supported on Windows 7?
  • sesa177673
    sesa177673
‎2018-09-06 01:30 PM
Windows 7
Webstation 5.1.X
Webstation works with Windows 7, but the reason why it's not officially supported is that the number of concurrent connections is limited to 10 (the same as in XP).
Webstation is not supported on Windows 7. If/when an issue arises our advice will be to upgrade to a server (2003, 2008) as unexpected behaviour may be resolved simply by doing this.
  • 5762
