Is Niagara R2 compatible with Windows Server 2003?
  • Is Niagara R2 compatible with Windows Server 2003?
  • sesa119747
    sesa119747
  • WaynePeters
    WaynePeters
‎2018-09-06 02:39 PM
  • Niagara R2
  • Windows Server 2003
Compatibility
Niagara version 514 and higher was officially certified to operate with Windows NT, Windows XP, and Windows Server 2003. As a side note, if using Windows Server 2003, there are two issues to be aware:
  1. Windows Server will use IIS services causing a conflict with TCP port 80. This will have to be addressed when engineering the station database.
  2. There is an issue with Niagara and Windows Server 2003. Tridium released a Tech Tip as follows: R2 Web Supervisor on Windows 2003 Service Pack
  • JDE will not start. If fui.exe is run from within the Windows command prompt, the following error is displayed: Error occurred during initialization of VM Could not reserve enough space for object heap. The problem is limited to instances where the user is accessing the computer with a Remote Desktop connection. On 8/8/2006, Microsoft issued an update KB921883 which unintentionally causes problems with applications that use large amounts of contiguous memory on a Windows Server 2003 Service Pack 1-based computer. There is a Hotfix now available to resolve the issues generated by this update. Hotfix KB924054.
  • TAC IA Series
  • 3372
