Inter-card Interval - Change the card reader processing/response time
  • Inter-card Interval - Change the card reader processing/response time
  • sesa150561
    sesa150561
‎2018-09-06 02:17 PM
After a card swipe it takes to long/short before another card can be used?
How to change intercard interval.
I/NET
Card readers ( any type )
In I/NET door editor there is a option called "InterCard Interval" This option can be changed to a desired number (second).
This option will determine how long it will take for the reader to accept a another card read after the first swipe.
To get to door editor navigate to
Access - door - modify (The door that has the reader where the problem exist)
This can be read in the "Door editor help"
Set the Inter-card interval (sec). This specifies the minimum acceptable interval between key/card reads. The interval can be from 0 to 255 seconds.
  • TAC INET
  • 4323
