Integrate a Datacard (ID Works) Video Badging system together with an existing I/NET Seven system.
  • Integrate a Datacard (ID Works) Video Badging system together with an existing I/NET Seven system.
  • Derrick_Ratliff
    Derrick_Ratliff
  • Tom_Poovey
    Tom_Poovey
‎2018-09-10 03:30 AM
  • I/NET Seven
  • ID Works Video Badging software version 6.5
  • All Windows version that are supported in the current I/NET Version of 2.42 and below
I/NET Seven and ID Works need to work as an integrated system.
The attached White paper defines the necessary steps required to modify the ID Works to operate in the I/NET system.
Note: if using 64bit OS such as Windows 7, a patch is required which makes ID Works 64bit. It is available from the 3rd party vendor.
http://www.datacard.com/id-software-support-and-upgrades/id-works-identification-software
  • TAC INET
Tags (3)
  • 6391
  • Datacard
  • ID Works
