Installing VisiView and VisiSat 2.1 build 14,17 and 137
  • Installing VisiView and VisiSat 2.1 build 14,17 and 137
  • Gary
    Gary
‎2018-09-06 03:03 PM
Installation
  1. The installation of VisiView automatically installs VisiSat 2.0
  2. If you have installed VisiView, you will need to Uninstall VisiSat 2.0
  3. Then install VisiSat 2.1
  4. If you install VisiSat 2.1 first, When you install VisiView your VisiSat 2.1 installation will be left at VisiSat 2.1
  5. VisiView will not work with VisiSat 2.1 Build 148
  • Satchwell MicroNet
  • 2160
