Installing TAC-branded (Niagara G3) and Vykon-branded (Niagara AX) versions on the same computer.
  • Installing TAC-branded (Niagara G3) and Vykon-branded (Niagara AX) versions on the same computer.
  • WaynePeters
    WaynePeters
‎2018-09-06 01:42 PM
A computer was installed with version 3.5.34 of Tridium's Vykon-branded Niagara AX and Schneider-Electric's TAC-branded Niagara G3.
An error appeared indicating that the core distribution files were missing.
Niagara G3 Workbench
The sw directory was missing under the 3.5.34 directory.
Un-install both versions and re-install just one of them.
The Vykon-branded and TAC-branded licenses files can be kept in a separate directory and swapped in-and-out as required.
  • TAC IA Series
  • 5400
