Installing SPP110 pipe pressure sensor on CPVC pipes
  • Installing SPP110 pipe pressure sensor on CPVC pipes
  • SESA150559
    SESA150559
‎2018-09-06 11:02 AM
Is it possible to install the SPP110 sensor on a CPVC pipe system?
SPP110:
004702020
004702040
004702060
004702080
004702100
004702120
004702140
Application suitability for plastic CPVC pipes.
The SPP110 sensor is delivered with a G1/4 male thread on the sensor body, and then an adaptor to male G1/2 thread. It needs to be determined locally if a suitable threaded fitting (female) can be securely adapted to the CPVC pipe.
  • Field Devices
  • 11332
