Installing MicroNet View software with I/O server installation.
  • Installing MicroNet View software with I/O server installation.
  • Gary
    Gary
‎2018-09-06 03:03 PM
Installation
If you have purchased MicroNet View and an NCP/ARCnet or SNP I/O server, only install the MicroNet View software. You should not install the I/O servers from the disk supplied with the I/O server. When MicroNet View installs it also installs both NCP/ARCnet or SNPI/O server software. Installing the I/O servers again can cause a conflict.
If you have installed both, then Uninstall all the software and re-install MicroNet View only.
  • Satchwell MicroNet
  • 2161
