Installation of Vista 5.0.x on Windows Vista unsuccessful
  • Installation of Vista 5.0.x on Windows Vista unsuccessful
‎2018-09-06 02:45 PM
Installing Vista 5.0.x on Windows Vista and it failed.
  • Windows Vista
  • Vista 5.0.x
Vista 5.0.x is not compatible with Windows Vista
First, uninstall anything Vista 4.3.x to 5.0.x installed including Microsoft SQL and Microsoft Visual Runtime C++ stuff. If they won't all uninstall, you may have to do a system restore to some point previous to the TAC Vista install. Next remove the c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Data assuming that TAClogdata.* is there. It might be in MSSQL.2 or other.
You should then be able to install.
  • 3136
