Inserting a 901 network into Xbuilder in Vista 5.0.2/5.0.3
  • Inserting a 901 network into Xbuilder in Vista 5.0.2/5.0.3
  • SESA116857
    SESA116857
‎2018-09-06 02:45 PM
XBuilder will allow you to insert the Xenta group or LonWorks group found under the Xenta 901 port object, but when you add the second group it will add it as a totally separate tree object instead of integrating into the same tree. For example XBuilder will show you this:
LON
  -XG1
LON
  -XG2
When it should look like this:
LON
  -XG1
  -XG2
  • Xenta 901
  • XBuilder 5.0.2 and 5.0.3
If you have an older site that is still using a dial connection via a Xenta 901 from your Vista front end and you need to add a Xenta Server to the site to perform connection objects from Inovonics or a 3rd party interface and do not have the option of adding an IP connection to the site then engineering this can be problematic in Vista 5.0.2 or 5.0.3 due to Xbuilder limitations.
To correct this problem, use XBuilder version 5.0.1 stand alone. This will allow you to make the proper tree structure when you insert the groups from Vista and create connection objects for your communication.
  • 3130
This is a heading
