In a Niagara R2 station, the ProView for LON Display wizard initializes with "Nv Type Lookup Error".
  • In a Niagara R2 station, the ProView for LON Display wizard initializes with "Nv Type Lookup Error".
  • sesa119747
    sesa119747
  • WaynePeters
    WaynePeters
‎2018-09-06 02:32 PM
Niagara R2
The ProView wizard for R2 displays a dialog box with error  "Nv Type Lookup Error" after the display is commissioned for the first time. The Workplace Pro DOS window will show a java exception as well:
OnInit_WeekSchedStep called. Disposal was interrupted: java.lang.InterruptedException
This is a nuisance error that occurs only with the initial commissioning of the display. Clear the program from the display and exit out of the wizard. Re-enter the wizard and begin programming. Subsequent commissioning completes successfully.
  • TAC IA Series
  • 3693
