In a Niagara G3 ENC, is there a way to view its diagnostic data without Workbench (i.e. CPU usage)? Assume the ENC is not licensed for web access.
  • In a Niagara G3 ENC, is there a way to view its diagnostic data without Workbench (i.e. CPU usage)? Assume the ENC is not lic...
  • sesa119747
    sesa119747
  • WaynePeters
    WaynePeters
‎2018-09-06 02:31 PM
Niagara G3 ENC
Alternative way to view the diagnostic data without Workbench.
In a web browser, type in the following: http://x.x.x.x/ord?spy:/ (where x = IP address of the ENC) After logging in, all the diagnostic and statistical data will be available via a set of links. It's the same information that's also accessible via Workbench.
  • TAC IA Series
  • 3732
