In a G3 MicroSmart station, does the station point name have to match the point name in the MicroSmart controller?
  • In a G3 MicroSmart station, does the station point name have to match the point name in the MicroSmart controller?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:42 AM
Niagara G3 MicroSmart driver
Replacing a MicroSmart controller database with a copy that has identical programming (including I/O assignments) but with different point names
The MicroSmart driver does not use the point name as the link between the G3 station's point and the MicroSmart controller's point.
If the I/O assignment is the same, then commands will work.
  • TAC IA Series
  • 15583
