In a Door object, the tick box "Relock upon Door Closure" is greyed out on the Channels tab. Is it possible to activate this feature?
  • In a Door object, the tick box "Relock upon Door Closure" is greyed out on the Channels tab. Is it possible to activate this ...
‎2018-09-10 11:42 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:05 AM
"Relock upon Door Closure" option is greyed out and feature is not available.
Continuum Access Control
The "Relock upon Door Closure" feature is not implemented at this time.
For this "Relock upon Door Closure" functionality you will need to use Plain English code. The code located here is a sample of how this can be accomplished.
  • 7961
